1986 mercury 75hp outboard ,came in won't idle ,wires to alternator stater were burned up only the two yellow wires from rectifier ,and the #4 cylinder wire was burned up to trigger repaired #4 trigger wire and replaced alternator stater also replaced rectifier engine will not idle unless holding throttle open don't know timing if timing problem please help.
