I have no spark on any of the four plugs. I have tried moving the bottom cdm to the top because the best I remember reading somewhere it starts with the fire at the bottom which is then tranfered to the top cylinder. Anyhow, I have moved the cdm's around to see if one of them was bad and still not spark on none of the four cylinders. What next? Am I looking at a bad stator? Also, could the ignition switch be a cause of no fire? I have multimeter and was curious of what to look for or any test to be done. Any information would be great.
