I have a 1996 mariner outboard which has a bent and twisted prop shaft. I need to remove it. I'm at the point where I have all the outer parts removed, only the shaft is left attached to a clutch and gear behind it. Is there a cross pin of some sort in the clutch holding the prop shaft in, and how do I remove it?
