Thanks in advance for any help that I may get with this.
I rebuilt my carburetors yesterday because the engine was running a little rough and not cranking as it should. I got everything back together and tried to start the motor and the starter spun but did not lift to engage. There was also some smoke coming from one negative wire on the solenoid and the groung that is just above the solenoid. I replaced the solenoid and the wires but I am having the same problem. Any ideas??
I have some pictures as well if that would help.
