Fishcake42
- Sep 12, 2013
- 19
Hi guys, kicker sorted, now on to the main engine.
3-cyl, twin carb 2 stroke Merc. Still trying to narrow down the symptoms, but the main element is stalling. Last trip out would stall under load if attempting more than idle throttle. Testing at home in tank will now run under load, but stalls with rapid return to low rpm/idle.
Would sometimes start no problem straight after, other times not. Tested with new internal fuel system, and with stand alone tank and primer, confident it's engine related. Fuel pump tested (diaphragm good) fuel flowing, not a huge stream but it flows. Carbs cleaned thoroughly and blown through, floats adjusted and mixture returned to average (1.5 turns). Good compression (123/120/120), whilst writing realised I didn't get round to the spark test today (will do and update).
Engine new to me and I think previous owner was a bit happy with adjustments as have found a Number of things way off spec (and the assurance that the carbs had been rebuilt recently was nonsense) First question is could this be timing related or would you guys be looking elsewhere?
