The overheat alarm sounds after 5 minutes or so. There is a steady stream of water from the test nozzle at the rear of the engine. If the alarm sounds and I am getting water from the test opening would it be the impeller?
Or could it be the thermostat and what is a good test for that?
Or could it be the sensor itself and is there a simple test for the heat sensor.
Then I've read about an engine block by pass. Could it be that and how does one know?
S/N OG558922
S/N OG558922
