jbjennings
- Jul 18, 2007
- 3,903
Pistons in merc 650 have "boost ports"???? I'm rebuilding it due to detonation and other problems. I've got some used pistons in good shape that fit good, but one of my new pistons does not have the hole in the piston skirt that I believe is a boost port.
Question, can I still use the piston without the boost port, or do I need to drill one in the piston that does not have one, or just get another piston?
Also, the newer used pistons fit perfect, but have holes drilled into the wrist pin hole in a different place. Is this newer design compatible with my old '74 merc 650? They did not come out of a 650, but another merc of a different horsepower.
Thanks fro the help,
JBJ
JBJ
