This looks like a pretty popular website for boating issues, Mercury Marine equipment for this particular question, so I thought I would signup and post!
What would the most probable cause be for the inner mounted Switch Box on a Mercury 175 HP outboard to repeatedly fail?
I have a 1980 Mercury Marine 175HP V6 outboard (S/N 5489172) which suffered two Switch Box failures within a couple trips out on the water recently. This motor has seen freshwater only. I replaced the first Switch Box several years ago, but the boat sat for approximately 10 years without being used. I also replaced the idle control and coil wiring during the first replacement due to wire insulation degradation (a common problem on the year range). I don’t remember exactly how much time was placed on the first replacement Switch Box, but the boat was used quite often around the time I replaced it. Flash forward to today, I put the boat back in service recently after the 10 year storage period, and after about 3 trips out (~2.5 hours run time each), while idling, the motor dropped power and would not accelerate onto a plane. After limping back to my pier, troubleshooting found the there was no spark on the right back of cylinders (#1, 3 and 5). Swapping the inner and outer Switch Boxes around confirmed the no spark condition followed the faulty box. After inspecting all the wiring, grounds, stator/trigger resistance checks and whatnot (everything checked within spec cold), I replaced both boxes with a (used) pair and the motor ran great, for about 3 trips out at which time the motor started missing while under power (I thought it might have gotten water in the gas based on the way it was acting). It did clear up long enough to get back home, but after sitting a week, it did not have enough power to plane out again. Troubleshooting again confirmed cylinders 1, 3 and 5 are not firing.
Before replacing the Switch Box again, I thought I would see if there were some lessons learned out there. A little internet research did confirm that there appears to be a large amount of Mercury Switch Box failures, but little information concerning the possible root cause. Thanks!
