Can someone tell me the correct compression ratio for 2006 40hp 2 stroke 3 cylinder mercury. Thanks
M mangrove Recruit Joined Sep 6, 2013 Messages 1 Sep 6, 2013 #1 Can someone tell me the correct compression ratio for 2006 40hp 2 stroke 3 cylinder mercury. Thanks
JB Honorary Moderator Emeritus Joined Mar 25, 2001 Messages 45,907 Sep 6, 2013 #2 Re: what is mercury 2006 model 40 hp 3 cylinder compression ratio HI, mangrove. :welcome: Are you sure that you want the compression ratio? Maybe you want the compression test numbers you should expect. Here is that test: http://forums.iboats.com/johnson-ev...ion-test-jb-313963.html?highlight=compression. The three cylinders should measure within 10% of each other.
