Re: Question: Water Pump and "Cooper Tube/pipe" Merc 150-V6/94
I think I found my problem. I took pump housing back off along with the top gasket, metal gasket, and gasket below. I then removed the plastic piece below that and found another gasket which the whole back edge was gone and pieces of it were laying in the area where water comes in from the low water pickups. Also there were a couple small pebbles or sandstones and some grit and sand. I dont think it was enough to block the some water flow BUT with the back of the gasket gone it was probably sucking air and not providing a air tight seal so it could suck water in and move it around the impeller to the copper tube and up to the engine......also, my blue seal was pushed in on one side a lower unit oil was starting to seep through into water chamber. not the propeller seal but the seal below the water pump gaskets and housing and piece below that..........How do I change that seal. I have drained all the oil from lower unit and not what?
