icelander295
- Sep 3, 2013
- 3
have a mercury 650 tied to a white quicksilver control box.
unit would not go into reverse (ratcheted prop when pulled into reverse) I was told were worn shift cam and follower by a boat shop when seals etc replaced. I replaced the follower and shift cam but the unit would still not fully engage into reverse.
The shift cable is adjusted all the way to the end of the adjustment but the unit will not go into reverse. I dis-connected the forward reverse cable and the motor will manually go into reverse perfectly but the control box won't adjust back far enough (1/8 inch more required)
I shifted the control box from neutral to reverse last night while disconnected and now the control box will not go back into neutral from reverse (stuck) I can move it back down to full throttle in reverse but when moving it back to neutral it stops like it is hitting a stop.
Can I assume the control box has something jamming it as I have the throttle cable and shift cable off.
the not going into reverse fully issue, does this mean my cable is NG
Will one of the black mercury controls work on my engine as I found one from a 16 foot boat that is black, but my boat is only 14.5 feet? Issues?
