Re: How to re-install lower unit 1972 80 hp mercury
I need a new ignition switch for it and mine is the one with the black remote control with blue stripe. Mine is a 5 wire switch all I can find is a six wire switch. Also do you know if there is a thermostat in in this motor.
I have tried that, but when I put the lower unit in neutral and the shifter in neutral, when I install it, the footing shifts into gear. How can I keep it from doing that.
thanks for writing me and helping with the info.
