Jesse00721
- Mar 18, 2008
- 16
I have posted on other forums and get no responses so I thought I would give this place a shot! Here is my issue, I have a 99 merc efi 150hp that I have not messed with for a few years. Now before it smoked like you just set off a smoke grenade. Recently started looking into it again. Engine actually runs well on a stand with even compression. Not perfect. Maybe 105psi in each cylinder. Smoke is not as bad now but the oil return line (line off the bottom crank which pulsates spits out premixed gas instead of what I think should be excess oil. If I put a return tank on it it would fill up with a mixture similar to a 50:1 mix. Now, I have tried 2 different mechanical fuel pumps, 2 different ecu!a and 2 different intakes with different injectors. Pulled all reeds and have less then a .020 gap on each. My original vst had a broken float and no one had one in stock so instead of waiting 2 weeks for a new float I bought a cheap vst but it was for a 3.0 liter. Hooks up the same, only real difference was the high pressure fuel pump was mounted in the tank instead of on the outside. Does not matter but no matter what is changed I can't seem to stop fuel coming out of the oil return. Does anyone have any idea what the issue might be? Thanks, Jesse
