I'm a newbie to boat engines but mechanical minded. I have a 1984 25 merc that I have gotten running but I can't figure out how to rev the engine in neutral. The steering arm has a forward and reverse on the handle and in the middle of that is a "N" for neutral however. It turns left and right fine but goes into gear when you turn it. I can rev the engine with the cowl off by using throttle controls under the cowl. I would think the handle pulls or pushes in or out but it does not. There are no levers on the side of the engine. Anyone remember how to do this? Thanks
