I have an early 90's model 90HP mercury outboard. It has 3 solenoids with tilt, trim and starter solenoid.
I recently took it out and it cranked when launching fine, but after running a few minutes and cutting it off all I got was clicking from the solenoid, but the starter would not turn over. I had a jump box with me and was able to jump the starter and it cranked fine. After diagnosing this I assumed the starter solenoid was bad and so I found one local and replaced the solenoid. After replacing it the motor started fine, I tested it a few times and then took it back out on the water. Everything seemed perfect.
After cutting the motor off I sat a few minutes in the water enjoying the view and then tried to crank it, this time same clicking noise and finally I could hear the starter spinning with the key off, and out of the ignition. So I disconnected the battery and reconnected it, this time it engaged the bendix and cranked the motor. I got back to my wet slip and cut the motor off with the key but the motor was still spinning. Again, I disconnected the battery. After waiting and let it cool off a few minutes, I tried reconnecting the batter and it instantly tried to turn over the motor. The whole time the key was out of the ignition.
Did I get a bad solenoid that worked temporarily and is now welded in the permanent "on" position?
Here is a link to the solenoid. Mercury - Quicksilver Starter Sl Solenoid Step Base 89-96158T - Solenoids - JMSOnline.net Marine Supply and Boating Store
