Mylittlemoneypit
- Aug 27, 2013
- 3
Hi first post here. I'm a real newbie. I have purchased a 20ft triton with a 2006 Merc Pro XS 225. All of a sudden the boat will not come up (or will barely) come up on plane. The nose goes way up and it throws water ten foot high. But unless I just go WOT and hold it there it won't get the nose out of the air. When I do go WOT it takes about 3-4 minutes to come up on plane all the time throwing water straight up and vibrating the boat tremendously (trim is all the way in/down). The local boat retailer said it was a bent prop shaft. I decided in a genius :facepalm: moment to figure it out myself. I have completely torn down the lower unit. There was water in the oil, the prop shaft was 5 thousandths off (tolerance is 7 thousandths) but no gear damage and no bearing issues. Now I'm putting this together (with new prop shaft and drive shaft, new seals, and some new bearings) and I'm questioning whether I have chased the wrong cat up the wrong tree. Could this be a power head issue? How do I check for that? Anyone had this experience before? Any help would be appreciated.
