Re: Mercury HP Gear Lube
However you should consider using marine hypoid type oil. The main thing is that marine gear oils are made with an additive that helps them cling to metal and prevent rust and corrosion. None of the regular GL series of gear oils, of which I am aware, have this additive as they aren't usually subjected to the same type environment....unless you go mudding and get buried up to your running boards with goo.....maybe then. Grin
Mark
