Re: Mercury Ignition needed (How many wires?)
Did you try iboats. I just bought a Commander 2000 remote from them with an 8 pin control cable:
Pins:
1. Black/yellow stripe, grounds trigger module and shuts down engine
2. Purple is 12v applied by the ignition switch being ON or START
3. Tan/Lt. Blue stripe, OT or oil warning
4. Black, battery -....ground
5. Grey tach signal
6. Yellow/Black stripe, fuel enrichment solenoid energizer (aka choke function)
7. Yellow/Red stripe, Starter solenoid energizing voltage
8. Red/Purple stripe fused 12v from engine 20 amp fuse
Maybe they have the ign switch to go with it or go to Merc Marine.
Mark
