motor boater
- Dec 24, 2012
- 219
I have a 1982 40 hp "2 stroke" Mercury outboard that I purchased a few months back. I changed the impeller and gear oil as well as the starter brushes due to a bad brush. I just put it in the water last week and it started and ran fine.
After pulling the boat back out of the water and onto the trailer, I noticed some oil in my splash well area. I didn't bother to check if it was mixed with burned fuel, because I just didn't want oil on my newly painted boat. so I flushed it with water and wiped it clean with a rag. It seemed sort of concentrated though so I'm not sure if it was mixed or not.
is this normal?
the boat sits kind of low on the back end and at higher speeds water does splash into the splash well a bit.
also while using it on the water, there was a little bit of white/light colored smoke that I could see sitting on top of the water from my outboard. this is just due to the gas/oil mix right?
another question is, where exactly is the gas/oil supposed to come out of after its burned?. I used a 50:1 ratio and I filled the 6 gallon tank with 5 gallons of mid grade fuel (not 87 basic unleaded, but not the highest one either 91) don't know if that makes any difference.
please help.
is this normal?
please help.
