Hi
I just wanted to post this question to make sure I don?t change "the wrong parts". A compression test showed approximatey 120 psi on all 6 cylinders with very small differences inbetween.
Motor is equipped with a Laser 2 prop, 23P. Boat is an english speed boat, a fletcher 16ft with a deep V-bottom. I guess the motor can be placed a hole higher on the transom, the cavitation plate is exposed on both sides of the V-skaped keel.
The boat has a top speed of about 41 knots (47 mph) with 2 persons. I calculated the total weight and got 1700 lbs (765 kg) including crew and all equipment.
-Is this a normal top speed ?
-If not, should I suspect that the motor is not performing 100% ?
-Is it really logical to expect 135 hp from such an old motor (1988) ?
-Do old outboards loose power due to age ?
Very difficult questions i assume, but I still wanted to get this off my mind.
Best regards
Hansen, Sweden
Best regards
Hansen, Sweden
