Re: 2002 mercury 60 not firing
It is possible that the stator died.
Disconnect the stator wires then repeat your Ohms tests, compare to your spare. If no continuity on the installed then I would seriously suspect the stator.
HOWEVER, DVA testing while cranking is THE most reliable testing method.
And remember that NO RETURN thing on electrical parts. You are lucky to have a 2nd stator, otherwise I would highly recommend DVA results before considering replacing anything.
