I have 2 WMA-9 carburators that have both been rebuilt along with new needles several times. The lower carb is dripping from the bottom again, and I believe is a needle/seat problem again, with the primer bulb going soft and the boat stalling occasionally at low speeds. It won't start again until I prime the bulb after it dies.
Since the last needle hasn't been in long, I suspect the seat is probably causing the problem, but the seat doesn't come with a rebuild kit and can't be replaced. Anybody ever found a way to clean up a permenant carb seat? I thought about trying to disconnect and rotate the needle against the seat several times thinking there might just be some slight roughness or a tiny spot on the seat that the needle would smooth out, but don't want to cause a bigger problem.
Thanks!
Thanks!
