I am repairing a 50hp fourstroke mariner 1997 model.should I rebuild the oil pump or replace it.#1 cylinder rod and journal are damaged due to lack of oil.the crank is going to get repaired and I will be getting a ne rod along with new pistons and rings.can I get oversized rod bearing if the crank has to be turned?
