Hey guys, I have a 1982 mercury 800 80hp I'm trying to get running. It will hit and run when gas/oil is sprayed into the carbs. I have tore the carbs apart and cleaned and inspected. I found no issues with those so I re installed them. When I pump the bulb it is hard as a rock and I cannot get any fuel to blow past the needle and seats. I pulled the main jets/tubes out and the fuel flowed freely out there on both carbs. That leads me to believe the main jets are possible clogged or the venturies may be clogged or maybe float issues. If it had float issues it would not have a free flow of fuel at the main jet/tube holes. Any ideas would be greatly appreciated, thanks.
