Re: 2000 mercury 50 hp adjust idle mixture & idle speed serial # otd62658
Your engine serial number is not lettered or numbered correctly. otd62658 comes up as Serial Number not found. Please try again.
I presume this is a 2 stroke engine and not a 4 stroke? If so then, the link below should help with your engine idle set up,
http://1manual.com/Mercury manuals/Service Manual PDFs/TwoStroke/852572r1/2c.pdf
But if you plan on running at 3,500 ft then you may need to change out the main fuel jets.
High Altitude Jet Chart
Factory installed main fuel jets are normally adequate for proper performance up to approximately 5000 feet
(1524m) above sea level. Between 2000 feet (609.6m) and 5000 feet (1524m) the reduction of the main fuel jet(s)
may result in improved performance and fuel economy. Above 5000 feet, however, it is recommended that main
jet size be reduced as shown per 1000 feet (304.8m) in the following chart. RETURN TO LOWER ELEVATION.
Carburetor jet changes must be reversed to avoid a lean fuel condition when used at low elevation.
See page 3B-12 for the chart list,
http://1manual.com/Mercury manuals/Service Manual PDFs/TwoStroke/852572r1/3b.pdf
Hope this helps, Good luck.
