Grasshopper579
- Jul 4, 2012
- 4
I have a 1995 Mariner Magnum III 150 h.p. 2stroke carbuerated outboard that has just been totally rebuilt,including replacing power packs,impeller,oil alarm control module,and oil tank float & cap,the one thats on the motor. My problem is after running about ten minutes today the oil siren started to sound.(The beep beep beep sound.) The oil tank on the motor is full,and if you remove the cap and start the motor it will over flow. The oil pump gear is also in perfect condition. What else could be the problem here?
