Boat has been sitting for a couple, so I took the carburetor off to clean it and replace the diaphrams. When I took it apart I discovered theres no spring under the primer diaphram. Is this common? Anything to worry about? There is a spring under the check ball, just none under the diaphram itself. Thanks
