Mariner 30 HP 1989 Made in Japan ( 30A EL 689-413869 - 689-416198 1985 )
Should the prop spin when turning the spline while LU is dropped? And if it should turn, what is my next step to find the problem? (Is there any shift linkage connections to check without tearing apart the lower unit?)
This motor is new to me, was told had electrical problems, replaced bad coil, got it running, now it wont shift gears or spit water out the tattle tale. Pulled Lower Unit from motor. When I spin the spline it does not spin the prop. Tried moving the gear selector and nothing changes. The prop is always able to turn in both directions freely. Even when it was attached to the motor the prop would spin freely no matter what gear it was in. The spline groves look good and so does the end up inside the power head. Looks to be no wear or damage to the spline where it connects to the power head.
