pinfish2750
- Aug 7, 2013
- 4
This motor has been sitting for 3 years with the old gas still in the carb. I know a little about carb rebuilds so I have cleaned and checked this one several times. I cannot get the motor to start without giving it half throttle. Once it cranks it will run as long as you give it some throttle, but it will not idle. I want to purchase this boat and motor, but not before it can crank and idle without having to manually pull the throttle cable. I have cleaned and checked the carb, cleaned out fuel tank, added high octane gas @ 50:1, new fuel lines and connectors, checked spark plugs. Any help is will be appreciated.
