Chinewalker
- Aug 19, 2001
- 8,902
I recently took a 1992 Mercury 15hp in trade, knowing it needed lower unit work. Turned out the gears are roached.
My motor appears to have the "Type I" lower unit referred to in the parts books, which doesn't look to have much in common part number-wise with the "Type II" units. My question is, do the lower units interchange, as a unit? I'm looking for either a set of gears or a complete unit, so I'd like to cast as broad a net as possible as I peruse eBay, etc. If I'm stuck with looking for the '86 to '93 unit, that's fine, but if the Type II, which was made up into the 2000s, will work, too, then I don't have a problem looking for one of them, either...
Thanks!
Thanks!
