For those that have a 9.9 Mercury / Mariner/ Yamaha that have these electronic valve sitting on top of the carb that fail . (Engine hard starting etc.) you can take off this part and test it with 12 volt battery and if it does not pull in in 5 minutes it is no good.
The power coming off the engine to the valve is around 6 volts A/C and increases with more throttle .
Price for a new one is around $100. how long will it last ?
My fix was to cut off the little piston valve from the electronic side and cut off the wires and place it back on the carb with rubber seal. If you get any air leak it will not start.
Tape up those supply power wires and and leave them alone on the engine.
Engine started just fine after this fix.
Not really sure if it is a choke or emission item added . They are just junk.
Now it runs like a Merc!
JR
JR
