Hi there, hoping someone on here can give me some ideas, I just got my engine back from an outboard repair guy, the whole thing has been quite a saga and without going into too much he basically took 6 & 1/2 months to get it fixed, has had new piston ring another piston all new seals, new shaft oil seals impeller and housing and all work was done properly, so after such a long time and a lot more expense than expected we were very excited to get our engine back this week.
Today I have a chance to try it, the strangest thing, it pumps water fine in neutral even when revving up but when in gear on the boat (10ft fibreglass row boat type) it only pumps water fine at low revs as soon as you try to put the revs up it stops pumping water. Does anyone have any ideas what this could be because after all the hassle I had with the outboard guy I just don't think I can do another episode with him unless I really have to. It just seems really weird because when not in gear it pumps water well even at high revs, as soon as in gear when you start to go over idle speed the water heats up dramatically straight away then stops pumping water altogether just blows steam, anyone know anything please I would be really happy to hear some thoughts on this. I was wondering if it was to do with the depth in the water or the angle or something, although I tried other positions for the engine, I really have no idea I just hope its easy to sort out as this is driving me nuts, the boat front does seems to rise up a lot but I didn't think it would stop flow to the engine? Thanks for your help, Jon
