JB Weld is an Epoxy.
Is it where heat or water is? How about a picture? If you have corner I suggest you have it welded and ground down as it will hold better than a epoxy....
I believe that JB Weld is a fairly decent one for what you're looking at. You're going to have to clean and prep the surface fairly decently, remove any corrosion and paint around it.
have never found glue to work where things should be properly welded. have you tried ebay? motor parts are cheep
Obviously, a new/used part would be a better choice than repairing; HOWEVER, JB Weld (A GREAT EPOXY) is super strong, and fairly cheap compared to a replacement part. I would no-doubt give it a try. What do you have to lose?
I found the part on ebay used for one third the cost of new. I think I'll go used rather than repair. Thanks for the advice.
