Hey folks first time here, have a 1984 Mercury 115HP inline 6, before I put boat in water everything worked fine, foward, reverse, idle, no problem, compression 120#s across the board, put boat in water under load in foward and ran fine at about 1500 rpms put boat in reverse and stalled out, would not restart for about 20 mins and then same problem and symptoms all over again....does it possibly need fuel pump kit or maybe something more extensive.
any help would be appreciated
Thanks
Thanks
