I have a 70 HP Mercury, that while running has no water pressure to the motor and no water coming out of the pee tube. I have replaced the water pump and impeller, I also back flowed water through the top of the motor with the lower unit off to make sure there was no clog. After doing all this I still have no water pumping through the motor. I did notice that when I run water into it from the top that it will drain out through the exhaust port under the cowl. Can anyone help or give me some ideas? I ran it with water muffs and with it submerged in water and no change. I also double checked the water pump to make sure the impeller was in the right direction. Thanks Ross
