stuckinthehole
- Aug 13, 2011
- 46
I have a 1997 Mercury 90 hp 2 stroke 3 cyl. outboard on my 19 center console. The tach is not working. When cranking the motor the needle does move a bit but once started it doesnt read anything. checked the voltage on the battery with the motor off and read 12.2 V and then started it and still reading 12.2 V. The gauge is new so it shouldnt be that and I am pretty sure the wiring is correct. I just finished a rebuild of the boat but the tach did not work prior to the rebuild. Heard that it may be the recitifier since the battery is not getting a higher voltage when the motor is running. Havent been able to troubleshoot much yet but should be able to try some stuff out on it tomorrow after work and give more details then. Any suggestions on what I should try first?
