88Glastron
- Nov 11, 2008
- 34
I recently purchased what I believe to be a 1989 Mercury 150 Black Max. The transom bracket serial number is 0C185152. Nothing in my manual for a 1989 seems to match my motor so can someone confirm this for me? I cannot find the freeze plug with the number etched on the block. The other reason that I am writing this is that I am trying to wire up the trim tilt inside of the motor and replace the bullet connectors with a waterproof plug. My question is the wires coming from the harness are blue green black and a tan that I believe is for the temp sensor. The trim tilt wires on the motor side are green blue and tan. Does the tan plug in to black at this point? I had someone assisting me that disconnected everything while I was out buying the connector and I would like some confirmation before Installing the pins. Thanks.
