help please
T TripleB Cadet Joined Sep 6, 2012 Messages 21 Jul 23, 2013 #2 Re: seeking schematic 1985 mercury 50hp. 4cylinder. Double check the SN. but should be this one http://www.maxrules.com/oldmercs/Wiring/1966ona/60.jpg
A appleo Petty Officer 1st Class Joined Jul 19, 2012 Messages 388 Jul 24, 2013 #3 Re: seeking schematic 1985 mercury 50hp. 4cylinder. TripleB said: Double check the SN. but should be this one http://www.maxrules.com/oldmercs/Wiring/1966ona/60.jpg Click to expand... Looks good What is gray wire from the rectifier to ignition switch for?
Barnacle_Bill Admiral Joined Feb 8, 2004 Messages 6,469 Jul 24, 2013 #4 Re: seeking schematic 1985 mercury 50hp. 4cylinder. That drawing doesn't show the ignition switch. What you are seeing is the harness an the gray wire if the tach signal lead.
