motoman125yztb
- Jun 29, 2013
- 26
Hey, same motor giving me problems. The motor will only run in neutral when bumped up. It will die even warmed when set to slow idle, or attempting to shift in gear. Fuel filter, fuel lines, and tank are new. New gas, carb is clean and functioning. When I pull plugs they have a dark grey to brown coating on them, smells like gas, but wont ignite when put to a flame. I was getting water in cylinder 1 so I replaced the exhaust port gaskets, and the head cover gasket, to inspect the water jacket. Now no more water. So the plug fouling seems to be the problem. compression on both cylinders is 118 psi. they both get good spark with an inline light tester. When I drop it in the lake I can make the motor scream up and will stay running when idleing high, but will die when returned to neutral idle, and when quick shifted it bogs and dies, I wanna see this motor gallop. I have set the idler screw to 1 1/2, all the way to 3 turns none yielding any positive results. Any ideas are appreciated. Thanks, Don.
