winner 2000
- Jan 8, 2012
- 5
checked archives and see nothing quite the same.
motor on tilt and trim went bad and was replaced (3 wire,3 ram type). now the motor drifts down,not fast but completes the up to down cycle in 5 minutes or so. unit would remain in up postion for days prior to changing motors.full of fluid and air bled,ran thru cycle at least 10 times and manual relief valve has good o-rings and tight. any suggestions?
