1991 115HP 2 stroke 4 cycle outboard needs the whole poppet valve cover and entire assembly restored. My biggest problem is previous owner had the boat in salt water environment and it appears the 4 or 5 cover screws are all corroded. I have already sprayed some petroleum base to soak and it's not working..I am only stripping the bolt head. I heard tapping on the screw head with plastic mallet and using a torch to apply some heat. I have only tried the spray but at this I wanted ask the experts for some feedback on how should I carefully approach this issue. I have the parts coming this week and this is only thing holding me back. Thank you any advice.
