Justchillin05
- Jul 15, 2013
- 1
While boat is moving at high rpm, sometimes the alarm goes off and it won't go off until we stop the boat and turn the engine off. Once we re-start, it is normally off. We just replaced the water pump and the "pisser" is working fine as far as we can tell. We are adding oil as we need and that part seems to be fine. Could this be a control module issue or an alarm sensor issue? What should we check first?
