logger don
- Jul 12, 2013
- 2
Recently purchased this motor and it appears it's been tinkered with a bunch. Haven't been able to get it to idle properly. Removed carburetors & cleaned. The float levels were set all over the place - I just guessed at setting them. Where should they be? Some of the vacuum lines were not attached, so I cleaned those up. I synchronized the throttle plates and adjusted the oil pump. It seems to run better but it still stalls out after 10-20 seconds. :facepalm: I noticed that the thermostats have been punched out so the motor always runs cold & just received new thermostats to try. Should this help? Also, has anyone ever had an issue with the flywheel seal suckin air and causing idle problems? Appreciate any help. I'm a blackmax newbe.
