phmorgan88
- Nov 20, 2012
- 10
Hi everyone, some great help and very informative info on this forum.
Been having a problem with my 2000 mercury 115 4 cyl having no spark on any cylinder.
I purchased a DVA adapter for my multimeter and tested the peak voltage on my stator and got 164volts max. The manual says should be 180V - 400V. My battery was fully charged. Is there anything else that could cause this low voltage or is my stator the problem and needs to be replaced? Resistance of the stator checked out at 680 ohms.
Thank you all for your help.
