orangeTANG
- Jul 9, 2013
- 17
I have a 1985 Mercury 18XD with electric start. I've finally had the time to pull my boat out of storage and I started to work towards getting it up and running. I went to use the starter and I got nothing but a pile of smoke pouring out of the motor and a strong plastic burning smell. I had to quickly disconnect the battery, which was tough to do because the wires and everything were heating up quickly.
The smoke and burning smell was the plastic covering on the wire between the starter solenoid & starter melting. I'm going to assume that I have a problem with either the starter solenoid or the starter itself. The screw on the bottom of the starter is loose between it and the starter casing and cannot be tightened, not sure if that is the problem or not.
Now my question:
Can I remove the starter from the motor and continue to use the motor without further damage? Do I need to keep the battery hooked up so I don't cause damage to the charging system. Do I have to do anything with the starter solenoid?
I've found some starters & solenoids on eBay for $70 & $20 each, but they will take some time to get to me, so I'm looking for a temporary alternative. I don't mind pulling a bit if it means I can use the boat.
Any help would be appreciated.
Now my question:
