Pinion gear is stripped on the starter, I can't find any numbers on my starter to get the right part number for the starter gear, it's an 8 tooth gear, does anyone know where I can find one that will fit?
Thanks
Chris
After doing a little more research, this is what I found at Mercury Marine
Service Literature for MERCURY NITRO TRACKER 125 ELPTO
PARTS CATALOGS •803168 - 100/115/125 Hp 80 Jet (4 CYL)
Normally to remove the nut you hold the armature shaft with one wrench and take the nut off the top with another. Have you removed the two long through bolts and the armature from the starter frame yet?
Do you have a manual? If not, post your engine s/n and if you send me a PM with an email address, I will send you a copy.
Thanks for all your help....
I have taken the long bolts out but haven't removed the armature yet, was afraid of stripping the shaft or busting something else.
S/N OT301502 M/N 1125412YD
Thanks
Chris
