First off I'm new so please excuse me if this is a frequently asked question/problem.
I have an 88 or 89 Mariner 60 hp 3 cylinder that I'm trying service the water pump on. The lower unit is stuck. After removing 1 nut on each side, one nut above prop, trim tab, and nut under trim tab I was able to drop it maybe a quarter inch and it won't move anymore. It also has more play at the rear than at the front. Is there any shift linkage that has to be removed? If there is, I haven't removed it or even found it. I've tried wooden wedges in the small gap with no luck. Any suggestions would be greatly appreciated.
Thanks in advance.
Matt
Thanks in advance.
Matt
