1949customf100
- Jul 6, 2013
- 5
hey guys, new guy and like usual the first post is a need help post. Just picked up a 14 foot cadorette/trailer/Merc 35 for $250, figured id take the chance on it, hell its got a scoop on it Previous owner said it ran fine last year and wouldn't start this year, The starter spins strong and cranks everything over but motor wont start.
the gas smelled like varnish so I emptied and cleaned the tank and lines, flushed/filled with new gas/oil and fuel treatment.
Plugs looked due so changed/gapped new plugs. Cleaned all terminal and dielectric greased everything. I don't know much about points ignition or what to test for at the coil (where ever it is )
Cut back battery cables till clean copper and put new marine terminals on
Ive tried spraying quick start into the carb but just cant get this thing to start. Im a hotrod/motorcycle guy and can usually get anything with a motor running, but my outboard experience is minimal. Theres also a missing switch on the top of the outboard casing, sure its not related but if you know what was there let me know. Any suggestions/troubleshooting scenarios would be greatly appreciated.
mercboat_zps2d4da248.jpg Photo by blingblingfire | Photobucket
merc1_zpse7b1940e.jpg Photo by blingblingfire | Photobucket
