Hi everyone,I have a model 200 20HP mercury I believe it is a 1976.It wasn't throwing any water out of the pee hole so I changed the impeller and that still didn't help although it did pump for a few minutes and stopped.So today I put a whole new water pump kit in and I have the same result. It will pump for a few minutes then stop but not really a steady stream its in spurts and when it quits it may start pumping if I restart.The copper tube is clean from the pump to the head.If I blow air into the pee tube hose it comes out at the top of the cowling could the seals where the copper pipe goes into the bottom of the motor be bad.I'm at a loss so any help would be appreciated.The motor starts with one or two pulls and sounds really good. Thanks MIke
