choogyddad
- Jun 30, 2013
- 7
I recently bought my first boat! It has a 1986 Mercury 60hp motor on it. The motor appears to be in great shape, and the old man I bought it from fired it up and let it run. Anyway, some of the wiring is cracked coming out of the stator. I removed the flywheel and pulled the stator off.
I have a .pdf manual that covers 60hp Mercury, and supposedly my year. The thing that is throwing me off is that the flywheel on mine is different than the one pictured in the manual, and the timing marks are a bit different. The manual says to set the timing to .459 BTDC, and the flywheel pictured has .459 scribed in it. My flywheel has 464 scribed in it. I am assuming that this means I want to set timing to .464 BTDC. I want to be sure this is the correct assumption. Also, I am not 100% sure what I need to do to actually set the timing.
My plan now is to use a dial indicator in cyl 1 to find .464 BTDC, and then install the flywheel so that the pointer on the motor is aligned with the 464 mark. The flywheel pictured in my manual is not the same as the one on my boat. Any help with this would be greatly appreciated.
